Brief Description: Cabin forwared deck and panel modifications
Continued work on the cabin forward deck structure, panel and sub panel. After doing the lefthand side parts on Thursday I did the same to the right side parts then re assembled and match drilled. the panel was repositioned using fillets and spacers and the exact position determined from the plan drawings and in discussion with fellow builders. Once all measured and lined up and squared I drilled the panel in place to the modified (moved) ribs left and right and attached with angle stock.
