RV-7A Tip-up QB build project
Date:  11-4-2011
Number of Hours:  9.00
Brief Description:  Fuel lines replacement, and make up
Removed the old fuleline tubing from the left and right of the cabin and straightened out ansd prepped the new stock tubing to replace the old system completely. Spent some time on the forward deck but hit a dead end / delay until the panel is cut I can not continue. Also encountered an issue with the map box, sought advice on the issue and recieed a reply or two in conjunction with my own research. Had a fellow builder pop in for a visit to advise on upcoming work and configurations.
