Started the re-fitting of all stripped components and assemblies from the now painted cabin. Installed the armrest stiffner mods as designed. Non-aircraft grade ally angle stock was trimmed to length, drilled and deburred. The 25mm ends bent down and drilled to fit the fuselage bulkheads. The angles were clamped in place, match drilled, clecoed and then pop=riveted in place for a secure, final assembly, made for a satisfying and effective solution to the flimsy armrests.
**Was ill today and will likely not be in tomorrow (Tuesday 23) to recover, and return to the cabin re-fit Wednesday 24th.
