Brief Description: Map Box and Wing pins, more Skyview Upgrade
Sharon finished up the map box and other instrument panel work. Kevin finished up the wing pins and drilled the new holes needed in the forward bulkhead as part of the Skyview upgrade. I worked the tail relay upgrade and cleaned up the workshop
We also planned to start running the harnesses. However, per an email... ============================== From: Notify To: @12_FINWH-00046.PML Subject: WH-OOO46 Fuselage Harness Copies to: shipping Date sent: Thu, 08 Mar 2012 10:02:25 -0800
The following apples only to those who received the WH-00046 Fuselage Harness (Finish kits shipped after August 2011)r parts
It appears that there may be a problem with your WH-00046 harness. The twisted wire pairs for the AHRS and the Autopilot pitch servo may be spliced in the wrong location. These wires are connected to pins 17, 19, 33 & 34 on the 37 pin board connector. The distance to the splice where these 4 wires become 8 wires should be 68-69" from the 37 pin connector. From the splice, the wires to the pitch servo should be 35-36", and the wires to the AHRS should be 138-139". . . . ============================== So one again on hiatur f
