Brief Description: Firewall Hinge Section and Roll Bar
Got an early start.
Sharon worked on the hinge portions that are used to hold on the lower cowl. While they may not look like much, but they were a minor PITA. Lots of small finicky fittings.
The roll bar was straight forward but time consuming. We primed inside of the rool bar once everything was match drilled and deburred. Riviting done, we mounted the supports and then tried to fit the roll bar and supports. That turned out to be a bit more challenging than it looked. Trick turned out to be to align the roll bar to the predrilled holes in the front on the supports. Once we figured that out, we called it for the night.
