Brief Description: Left wing bottom skins completed
Did the access panel and then mounted the middle (last) bottom skin. Flipped the wing over and then installed the flaperon hinge points. Learned a few things about that which will make it easier on the right wing. Clecoed down the leading edges where it wraps over. The outboard side was much more difficult than the other skine. Stall warning system still functions properly.
Made a short day of it and went out to dinner with Sharon and Aleta
