Pierce finally got that annoying white cable through to the avionics panel. unfortunately, we then had to disassemble the fuselage D-sub wiring harness to get those wires into the D-sub, so we did that. And then we had to take off the middle of the instrument panel to get another horribly placed D-sub off (using Allison's conveniently tiny fingers) and put another hangy offy wire into the harness, and reattach it. We didn't fully reassemble the instrument panel because there's another red wire we have no idea where it goes. Some other people did stuff with the spinner and the nifty new canopy latchy-doowop.
My diary Day 14,986 we made it to the next encampment, and found food and steady water supply. it's only enough for a few of us, the others won't mkae it. we won't tell them though, we'll let them have hope until the bitter end. The rest of us will continue on to section 33. We're burying the bodies in section 32 so we don't have the angry aero 1 ghosts following us. This ends my diary for today, If you're reading this, Install the wires before the entire panel. Don't suffer the same fate we did.
