We connected the forward fuselage wiring harness and stuck the wires through the fire wall to be continued at a later time. We connected the power wire to the positive side of the battery and left it for later connection. We began connection to connect the wires to the grounded side of the battery, however, the plans said to not connect the ground wire so it is not yet attached to the ground.
