Toda we finsihed up getting the rudder pedal control lines hooked up. We forgot we had to make 2 of each size of the metal spacer used for the foward rudder line hookups, so we had to double them. we used the magical rudder zeroing jig to keep the rudder pedals lined up and lined up the rudder, then final attached the rudder cables. all we've got left to do on that front is to use rubber hose clamps to attach the plastic tubes that keep the cables lined up, and Cullen will do that once parker finishes the pitch servo.
