Brief Description: Finsihing The wing tip and Flapperons
Drilled the holes for the light mount on the left wing tip fiberglass. attached the mount bracket and measured out to the hole for the light wires. drilled the hole and step drilled it further, but couldn't make it big enough. Elongated the hole to allow the wire harnesses through, left the wiring to Dean and moved on to the flapperon. Began deburring the skins, and clecoed some together.
