I fabricated the starter cable. This involved significant shortening of the Vans cable. I used a rotary abrasive wheel to cut through the cable. After fitting it twice and cutting off a bit more for the perfect fit, I used a tool to swage on a terminal and then added heat-shrink.
Meanwhile Cameron built a support for the cable as it crosses under the front of the engine
