Brief Description: Rewired VP-X J1, J2, Tested System
I swapped J1 & J2 for proper hookup.
I experimented with the configuration system and began testing the system.
I found that the VP-X will turn off a circuit if an under-current fault occurs, so I had to remove all of the under-current tests for my no-load testing.
I also found that the documentation I had prepared was out of date and a couple of the piins are hooked up incorrectly. I pulled two pins on the VP-X J8 to move the loads to the proper point.
I tested out all the wiring to the wings - all works OK.
