Brief Description: Programming Vertical Power System
I hooked up the power to the VPX today and started programming.
I noticed that I had put some low-current devices on high-current breakers. I think I will combine a couple and reserve a high current breaker for future use.
I then moved on to testing the system.
I noticed that I immediately had a fault. Tracked it down to a serious error - I had swapped J1 and J2 by mis-reading the manual. So, I have to re-terminate about 30 pins for DB25 connectors. I had left the pins and tools at the airport, so this will have to wait.
Overall, this is a minor error that should take around an hour to fix.
