I ordered mini connectors from Digikey. I spent a couple hours trying to get them crimped properly. No Joy. I also decided that I couldn't remove them with any tools I have - making maintenance a problem.
I switched over to large connectors - much better. I terminated the servo side, but put off wiring the connector.
I have to regroup on the stick grip switches. I need a connector. The mini is still on the larger side. The full size AMP connectors won't fit...
