I put in a forest of fast-on grounds on the bulkhead separating the instruments from the baggage area.
This will have heavy wire running up to the firewall for the single point grounding. I need to ordre a cable for the ground return. It doesn't have to be #6 - at least half of the load out of the VPX returns via the chassis. (mostly lights).
