Brief Description: Routing Wires Through Front Baggage
I connected one end of the main wire harness to the VP-X. I started routing through the baggage area. The time came to figure out where the wires will live.
I built the little bracket to attach to the upper stringer. The Adel Clamps will eventually be turned over to pull the wire in under the stringer to protect it.
I cut the end of the buss cable. I don't have ring terminals for the #8 cable. I figure I can get those at NAPA tomorrow. So, a good point to stop for the night.
