I mounted the bracket for the roll autopilot. Did the usual drill, debur, prep, rivet.
The servo is mounted just forward of the stick and will be easy to service.
Mounting for the rear servo required removing the aileron bell crank mount and replacing it with a bracket provided by TruTrak. (Shown Below) I had to crawl back in the belly and drill out rivets, debur the holes and rivet in the new brackets.
Installation of the servo motors will be delayed until final assembly time.
