It went pretty smoothly. I did have to remove the sensor manifold to get a 45 degree fitting installed correctly.
I decided to replace the legacy senors with accurate instruments compatible with the EDM. I used Honeywell where I could and Kavlico for the MAP sensor.
Fuel line to induction metering unit was simple.
The I also figured out the Adel Clamp sizing that I need. I had planned to order a bunch, but it seems that I had already done that.
