I installed the cabin heater box on the firewall. Simple and fast.
From there, I started figuring out the connectoins to the transducers. The Fuel Pressure sensor is ready to hook up. I just need the restrictor. I may make one or buy one from Vans.
The Oil Pressure port was installed in an awkward place. There is a much better port just an inch away. I think I will pull the installed nipple and replace it with a plug. It is in a very hard to reach location. I was able to get in a turn it 20 degrees to get a hose on it, but I really don't like the position.
I need to research an adapter for the manifold pressure pickup. And I need to decide what sensor I am going to use.
Not much to show, but it suddenly seems a lot more doable. It is just a series of little steps.
