Dans RV8
Date: 1-9-2013
Number of Hours: 1.00
Brief Description: Mounting Transducer Block
After fumbling around for way too long, I decided to look at the prints. Amazing. Lots of good ideas! I have to adapt a little as they are not exactly for my engine.
The bracket will hold the oil, fuel pressure and manifold pressure transducers. They are mounted on the firewall to minimize vibration. On the engine, they would fail quicker and could rupture. So, I get to run little hoses up here, then wires into the cabin. This is better than having fuel enter the cabin.
I decided that mounting the transducer block would give some quick rewards. It seems to be in the right place for my engine...
I quickly fabricated the doubler in Figure 2. It was nice to cut metal and work efficiently. All the normal theropy steps: measure, mark, measure, cut, deburr, drill, deburr again.
This wasn't a big deal. But I just did it.. No issues. Went pretty quiclyly.
Ready for transducers
Doubler in baggage area
