The primer didn't interfere with the markings on these parts so assembly was quite straightforward.
I did have one bad rivet which went from bad to worse as I tried to drill it out. The drill slipped a little off center and the hole became oversized. I had to order some -5 rivets to fill the oversized hole. This part appears to be way overbuilt, but putting in a larger rivet is the conservative way to go.
