Brief Description: Fast Stack distribution block wiring
Hooking up the other end of each cable was quite simple - just plug them into the Fast Stack distribution panel.
You can see that there are a jumble of wires. Fast Stack brings out most all of the pins, including a lot that I won't be using. For example, there are 8 User Input pins. I might use 2. There are two wires to control reversal of pitch inputs (wire it right and you don't need that...). But, better safe than sorry.
I pulled the power and ground wires out over the front of the panel to get an idea of the connector block system. I have about 15 power wires to hook up. The ground wires will all go to a single point ground block ont he sub-panel, which will then go with a heavy wire to the battery. So, all avionics will have a single point ground.
