Dans RV8
Date:  8-21-2011
Number of Hours:  3.00
Brief Description:  Basic Stack Assembly
I had placed the holes for the trays years ago. Has it really been that long?
I had to ream out the holes for a #8 screw. That all went pretty fast. From there, I mounted the trays to the newly made support bracket. I did all that before attaching the mounting bracket to the instrument panel. That made the work simple and fast.
I had to disasemble each tray to make replace the "experimental" connectors with those for the Fast Stack cables. (Garmin doesn't sell direct - shops have to do some value add. Mine pre-installed the power wires and sent along a bag of DB connector pins.).
Figure three shows the completed, modified stack with the new connectors.
From the Top...
Auto Pilot (Not shown here)
Audio Panel
SL40 Nav/Com
GNS430 Nav/Com/GPS
GTX327 Transponder
Stack Attached to Panel
Front view of stack
Front view of stack
One end wired!!!
One end wired!!!
