I spent a fair amount of time trying to figure out how to mount the Vertical Power CB system. Just below the radio stack looks promising from a lot of aspects. I have some interference with brake lines. To put it there, I woudl have to re-route the brakes. The other alternative is less interesting - putting it in the baggage compartment. That would have the benefit of being easy to work on in the futre, but I probably would want to encase it.
In the process, I tired to place the avionic to look for mechanical interference. That exposed another problem: i had lost some parts I had made for the avionics trays. That is one of the costs of stopping for a three plus years.
I moved on to finally do some real work - I started wiring the battery contactor. It went well, but I will take it apart again. I ordered some 5/16" lugs for the shunt diodes.
