Dans RV8
RV8 N14DB
Replacing Front Baffles
I decided to replace the front baffles to give better clearance from the flywheel. The design is similar to Van's new IO390 baffling system.
I made "paper dolls" to fit the baffles to the engine. I got everything close enough to use RTV to seal the baffle to the engine.
I will transfer these patterns to some scrap aluminum, make final adjustments, then cut new .040 sheet to make the final parts.
Left Front Baffle
Left Inboard Baffle
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
