Gary Prosenko and I worked on baffles again. The cowling was still binding with the upper cowl.
We got most cut down. The cowling is getting easier to install with each iteration.
We did find that the induction snorkel was still interfering with the alternator. I decided to sand a big hole in induciton which will need patching down the road.
We also found that the snorkel interfers with the prop governer bracket now hits the snorkel that it is up tight against the metering box. The solution seems to be to shorten and angle the prop governor bracket and/or move the top of the snorkel outboard slightly. Either way, it is a very tight fit, but still the lesser evil.
Not a lot to show, but we still made a lot of progress.
