It has been hard to get any work done for the past couple weeks - I have been working in So. Cal for JPI to help pay for the avionics. Seems fitting. Pity that I don't plan to use their instrument.
I have been able to make a lot of progress in the avionics planning. Just when I think we have all the wiring pulled, I find another wire to pull. The latest is that the traffic system needs a 1 7' antenna cable. I have already pulled a wire, but it is certainly not 17' long. So it will need to come out and be replaced when a new length of wire arrives.
I was able to build a new side panel for the right side today. I am a little unhappy with the countersinks we made in the other side panels last week. The material should have been dimpled. As a result, the holes are too big. I will probably order new side panels.
