I started with dressing out the cables for the lighting sub-panel. This is going to look very good when we get done. (Figure 2)
I then continued pulling wires to the left side of the airplane. I still need to run a nav antenna wire, but I am running out of room in the wiring chases. I will runn the comm antennas on the right side in a separate chase.
I roughed out the wiring to the firewall. I am short one cable, but I can continue with routing that assembly tomorrow. I also need to run the wing strobe cables.
