Dans RV8
Date:  8-9-2006
Number of Hours:  3.00
Manual Reference:  Oxygen
Brief Description:  Oxygen Tank Mounts
I am glad that we decided on the smaller O2 tank: the 33CF tank just barely fits. I planned to mount it transversely behind the aft baggage compartment and ahead of the bell crank. The tank is 7"; we have 7.25" of space.
I puzzeled for a while on how to mount the tank. I finally decided to use two 1" aluminum angles perpendicular to the floor supports. I started with 18" brackets. After cutting them, I decided that they didn't need to be that long as the valve end of the tank is narrow. So, I cut them down. After mounting them, I realized that there was still excess material, so I cut some more off. At least I got some aerobics using the hack saw!
I bolted up the system about 10 times before I got the fit right, but it looks pretty good. The tank is as far aft as practical and is well secured.
Bracket Assembly
Bracket Assembly
With 33 CF Tank
With 33 CF Tank
O2 Tank Mount - Aft of baggage
