I drilled up the right console. This went a little easier than the left. I used some scrap aluminum to create a drill template for the forward angle mount. Even then, I had to remake the angle part - the console is about 1/8" short of the ideal length.
I also match drilled the 804N side panels
As usual, I drilled out more PLATENUTS, deburred and primed all parts.
