I riveted up more platenuts to hole the servo in its tray. I then fit everything and did some minor trimming, followed by priming and pop-riveting into place.
I fabricated the trim pushrod. This required some fairly delicate machining to create a slot for the servo and get the spring holes properly positioned.
The servo will not be mounted until final assembly. It is easily accessed from the floor under the pilot.
