Dans RV8
RV8 N14DB
Adjust bracket
I used the abrasive wheel to increase the radius around the governor shaft by about .040. The bracket is nice and snug.
Unfortunately, the orientation simply won't work. The cable bend is too sharp and there is too much going on in that area.
I can either fabricate one that rotates 30 degrees aft (25 is better), try coming in from the top, or change to a McCauley prop governor...
Time to think
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
