I cut the safety wires and rotated the control head.
The radiusof the mounting brack is about 0.050" too small, I have the option of creating shims or filing out the bracket. The material starts looking thin if I take much out.
It also looks like Matt rotated his 30 degrees more. The control head mounting holes allow for rotation of 60 degrees. His appears to have holes aligned with the longitudinal axis of the engine, while mine are vertical. That means his pattern is rotated 30 degrees from mine.
I need to fit the intake manifold and see if the cable and all fit. I don't think there is room to rotate 60 ccw in my plane...
