I put in a few platenuts to allow me to firmly mount the rear floors. I then reinstalled the flap weldament. Next, I installed the flap actuator motor. I applied power to cause it to fully extend and then set it up with the 1/4" clearance called out in the plans. I tried retracting it and found an interference at about 15 degrees of flaps. I had to enlarge the actuator hole in the arm rest to allow free operation from min to max flaps.
It was fun to see the actuator move up and down under power. I removed the assembly and returned it to the parts bin. It will be reinstalled after the floor goes down the final time.
