Dans RV8
Date: 6-27-2006
Number of Hours: 1.50
Brief Description: Sorting and Binning Parts
I had left most of the parts in the Vans bags. For many things, this makes sense - they are essentially sub-kits, like Spar Carry Thru Bolts, Brake Reservoir, Wing Attach Bolts, etc. But for the generic items, it has been difficult to find the parts. Today, I needed to find the rodend bearings for the control column. Not too hard. But then I needed to find nuts (they were not in the bag).
I sorted out all the generic parts and stored in bins. Some bags, like the 8-32 Hardware, contained multiple part typess that needed to be sorted into separate bins. Others bags had so few items it didn't make sense to separate individual part numbers.
I found the nuts I needed. Everything is now organized and on the shelf. This should speed up assembly. At minimum, it will reduce frustration.
Organized Generic Parts
