After considerable research, I decided to go with frame grounding for the lights, pitot and fuel sensor. I wanted a good ground back to the engine mount. I decided to use the gold-anodized spar as the ground point. I installed FastOn tabs to the spar using brass screws to minimize corrosion. I will run a ground wire from the spar to the forest of tabs ground to complete the path.
