I got stalled on several fronts today. The Bell Cranks need to be reamed. The tool kit didn't include a reamer. So I ordered one, but it won't be here for a week. I moved on to the Push Rods. I did get the tubes cut, and measured for the 6 rivets at each end. I had to rearrange the shop to get to the drill press. I need to mount the drill press vice and wanted to avoid a trip to the hardware store for some 3/8" bolts. So I moved on, yet again, to the aileron hinge assembly.
First step, as always is debur and break the edges. I was able to use the bench ScotchBrite wheel on most of them, but had to do some sanding on the bearing area. Next step: Prime and Rivet...
