Dans RV8
RV8 N14DB
Rebuild Avionics Mounting Panel
I rebuilt the avionics mounting bulkhead to incorporate the new CNC cut panel.
The first step was to drill out all of the old rivets. I dreaded this, but it went quite quickly.
Next was the usual match drilling, deburring and countersinking.
Rivetting went pretty quickly. I did have to drill out about 10 rivets to get a smooth fit.
The notches for the longerons had to be opened up from about 0.110 to 0.140" The result was a very, very tight, precise fit.
I finsihed by ScotchBriting and priming the back side.
I need to do the same thing to the main panel, then send them all out for powder coating.
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
