Dans RV8
RV8 N14DB
Installing Avionics
I installed the avionics trays and modules in the avionics tray. Then I connected the wire harness to the FastStack module.
I found that one of the DB studs is broken. I will have to repair the unit.
Next step... Wiring power and ground.
Finally, it is lookig like progress.
Trays and Avionics Loaded
Still a lot of wires to hook up
RV8 N14DB Home
1209
187
Cabin Air
197
253
FAA
Organizing
Planning
Skills
