Davids Web Site
Date:  8-19-2009
Brief Description:  Right Elevator Fiberglass Tip
Worked on fitting the tip to the Elevator. Notched the inside trailing edge so the tip would fit inside the Elevator where the AEX wedge and the skins come together to form the trailing edge. Once the tip was fitted inside the Elevator the trailing edge of the tip was about a quarter inch longer than the trailing edge of the Elevator. I trimmed it to match and then after sanding the fiberglass tip to match the trailing edge surfaces of the Elevator I had to do some fiberglass reinforcing to make the tip fit appropriately.
