Finished riveting the right HS main ribs and started working on the left HS... same steps as the right HS. Placed two of the three inboard nose rib-to-spar-to-main rib rivets without incident. Amazing! Now I have to get more of the AN470AD4-8 rivets to replace the ones I bent and drilled out on the right side. I'll probably drive down to Van's tomorrow afternoon to pick up the replacement rivets. Also riveted the HS-911 inboard hinge brackets to the VA-146 bearing. Its now ready to bolt on when the HS is completed.
