Layed out the lines and holes for the brackets, cut them out and finished sanding them to size on the disc/belt sander. I used a neat little automatic hole punch tool to mark the #30 holes. I will drill small pilot holes and then drill them out to size. My tool kit should arive from Avery on Tuesday and then I can set up the Scotchbright wheel in my grinder and polish the edges of the brackets.
