Brief Description: H.T. Plate, Rudder Cable Outlet, etc.
Replace the top āLā angle on the rear H.T. frame. There was some misalignment on it when I put the top skin in place. I also fitted and installed the rudder cable outlet bearings.
Installed the linear actuator mount in the bottom right rear fuselage skin. After several unsuccessful tries of drilling the rivet holes from under the bottom skin, I carefully marked the hole locations and drilled the pilot holes in my drill press. Installed the part in the bottom skin, and drilled for A-5 rivets. Removed, deburred, primed and installed the linear actuator.
Updrilled the baggage back and floor for A-4 rivets.
