STANLEY'S WEB SITE
Date:  2-5-2010
Number of Hours:  5.50
Brief Description:  Wing Caps
Fitted left wing tip. The new wing cap from ZAC fits a little better, although not nearly as good as the right wing cap. Had my wife help install the wing tip while I drilled and clecoed the wing tip. Added the ā€œLā€ bracket to the spar extension for the middle of the wing tip per specs. Riveted wing caps to wing skins.
Finished installing nav. light bracket on left wing. Used the Molex connectors and left a hole sufficiently sized that the connectors can go through, thus making it easier to work on the Nav. lights. Installed Nav. light ground on the spar extension.
Cleaned and primed the Jabiru engine mount in preparation to take to the community college that is overhauling the 3300 engine.
Left Wing Cap
Left Wing Cap
Both End Caps
Both End Caps
Primed Engine Mount
Primed Engine Mount
