STANLEY'S WEB SITE
Date:  11-11-2009
Number of Hours:  6.00
Brief Description:  End Caps and Wing Skin
Finished fitting end cap. The fiberglass is very thin. Added alum. strip to bottom and top of end cap to allow better riveting. Had to remove the previously installed ā€œLā€ angle brackets form the spar and back channel. Made larger ā€œLā€ angles from scrap so that the sides of the angle touched the fiberglass, thus allowing it to be riveted per specs.
Put the main top skin on and riveted it except for the last two rivets on the outboard end. This will allow me to do the finishing work on the end cap.
Did some work on the top fuel skin. Enlarged the fuel fill hole to allow better clearance around the filler hole. Started fabricating a small cover plate would the evenly cover the excessive opening in the top fuel skin. The new piece will be added when the skin is riveted.
Reinforment for End Cap
Replace
Replace "L" Brackets
Installed Top Skin
Installed Top Skin
