STANLEY'S WEB SITE
Date:  7-14-2010
Number of Hours:  3.00
Brief Description:  Fitted Top Fwd Skin
Fitted the top forward skin with the cabin cage with great difficulty. Decide to cut out to the front where the cabin cage goes through to mate with the fire wall. That will allow access to that area in the future without a lot of dismantling.
Note: Take to Roger at Zenith on the firewall connection to the cabin cage. The plans show two bolts through the firewall to the front of the cabin cage but do not give any specifics. Roger indicated there should be two AN-3 bolts located 35 mm from the center on the rectangular support and spaced equal distance on the vertical axis. Another glitch in the Zenith plans.
Top Fwd Skin
Top Fwd Skin
Cut-out for Cabin Cage
Patch for cut-out
Patch for cut-out
