STANLEY'S WEB SITE
Date:  7-12-2010
Number of Hours:  3.00
Brief Description:  Rt. Seat Pand & Torque Bearing
Reworkded the Left seat pan. Cut 10 mm off the rear bracket, and rebent rear bracket to fit properly between the ā€œSā€ angle and the bottom of the baggage panel.
Had previously riveted the torque bearing without the arm rest side panel. Had to un-rivet and re-rivet the torque tube bearing with the arm rest side panels. Note, I only riveted the front of the arm rest to allow some movement in getting the seat pans installed once the various lines are run under the seat pan. Will still need to remove the torque tube to do the final riveting.
Re-Riveted Torque Bearing Support
