Finally figured how to connect brake lines on main gear. Also talked to Todd Ott, A&P at New Market Airport on how to secure the brake line on the main gear. He indicated that I could use adel clips of the line and that I should only drill on the center of the gear, only as far as needed to tap the hole for the bolt. Also contacted Matco and got a drawing on hose the brake calipers are to be connected on each wheel. Brakes and wheels had to come off to install the line between the calipers on the bottom as outlined on the Matco drawing.
Tried to do a little polishing on the fuselage skin. Seems to work OK but is really messy. Will polish when plane in is hangar.
