Fitted the rest of the control horn, only to find that the horn angle, that was located previously per the plans and specs. and it will not fit. Need to order another horn angle to correct the problem. Removed the nose skins and set up the trim line. Nose skin will need to be installed on the outside of the other elevator skins.
