Riveted Rear Bracket. Tried to put skin on bottom. Cannot be done and rivet the front brackets. Called ZAC, and much discussion, should put the skin on starting with the bottom first. That allows the skin to fit over the front bracket, then riveted bottom skin. Best solution was to remove the rivets from the top skin and start over. In the process, discovered that front bracket were too close together by 1/4 in on each side. Ordered new front brackets.
